Meridian Navigation Slow
We deployed a meridian installation in our office and the navigation is very slow. I use the appviewer to test the navigation. When I open the map, my position is accurate. But when I move or start the navigation and move, the Blue dot moves very slowly.
It takes >30 seconds , which is a long time for a navigation. It does not jump, it just moves the right way very slowly.
Is there any limitation with using the appviewer ?
Chris
MVP
Re: Meridian Navigation Slow
Chris,
Please double-check that you have set the Control points on all of your maps. To do so, go to maps, press the 'Edit' (pencil) for each map, and set the control points:
I know it sounds strange to link delays to not setting the control points, but I have seen it happen a few times.
As a guidance always set the control points first thing when you start doing work on a map.
Herman
If you have urgent issues, please contact your Aruba partner or Aruba TAC.
thanks herman, the missing control points caused our problems.
