RetailNext with Ekahau or Aeroscout Location
Team,
does anyone have expiriences with RetailNext?
Did they Support Ekahau or Aeroscout Location services?
I am working on a retail opportunity and the customer is focused on RetailNext.
The customer uses an existing HP Unified Wires solution with over thousand APs.
The analytics from RetailNext reqires wifi location from clients, HP UWW did not support RetailNext.
I would like to build a solution stack with 3rd Party Location services fron Ekahau or aeroscout.
Cheers
Philipp
HP WLAN Evangelist, Germany
Best regards
Philipp Edw. Kroencke
HP Networking
Re: RetailNext with Ekahau or Aeroscout Location
You may have better luck on the Ekahau or Aeroscout forums.
Aruba supports RetailNext through ALE.
Tim
Tim Cappalli | Aruba ClearPass TME
@timcappalli | ACMX #367 / ACCX #480 / ACEAP / CWSP
