What happens when I have 4 APs close to each other
Can someone please explain the sequence what happen if you install 4 APs close to each other, mainly on the 2.4 gig . Thanks
MVP
Re: What happens when I have 4 APs close to each other
When you have APs too close to each other you could experience some performance issues even if the APs are on different channels since the channel side bands could still make an impact on the other channel and create radio congestion.
That's why is recommended to have APs 25-30 feet apart
Thank you
Victor Fabian
Lead Mobility Engineer @ Integration Partners
Thank you for your reply.
any idea which channel DFS attempt to use for the 4th AP with channels 1, 6 and 11 used by the othe APs near by?
MVP
DFS is use with UNII 2 extended 5Ghz
In regards to the channel assignment if you have ARM turned on , the APs usually scans other channels then it analyzes the interference level seen on other channels and this information is send back to the controller and based on this information the controller will make the best decision on what channel/power each AP will be assigned
Thank you
Victor Fabian
