Occasional Contributor I
how to remove spectrum monitoring from radio profiles%0D%0A
I would like to know what is spectrum monitoring and how to check whether APs are running in spectrum mode or not ?
If APs are running in spectrum monitoring then how can i remove it from profiles. Appreciate your help.
Seshi.
MVP
Re: how to remove spectrum monitoring from radio profiles%0D%0A
[ Edited ]
If you do show ap active and in the flag you will see an "S"
Thank you
Victor Fabian
Lead Mobility Engineer @ Integration Partners
Can you tell me what is the purpose of spectrum monitoring ? and can you please show me the commands to see what are all radios in controller and how to remove spectrum monitoring from CLI ? Appreciate your help
MVP
show  ap active type spectrum
(controller) (config) #rf dot11a-radio-profile <profile name>
                                 no spectrum-monitor
(controller) (config) #rf dot11g-radio-profile <profile name>
                                 no spectrum-monitor
2014-06-17 19_19_18-www.arubanetworks.com_pdf_technology_TB_Spectrum-Analyzer.pdf.png
Thank you
Victor Fabian
Thanks a lot bro. Can you please tell me about certifications in Aruba. I am pretty much interested in wireless. I was confused from which certification to start with. In Cisco certification we've path like ccna-ccnp-ccie. Like that is there any path for certifications ??
If so can you please provide it. I would like start in wireless from scratch. I.e from college student to expert level. Appreciate your help
MVP
You can try the following :
CWNA > ACMA > ACMP
http://www.arubanetworks.com/resources/certification/
Thank you
Victor Fabian
