Airwave Device Connection Notification - Mar 2014
Community Manager
Community Manager
The tutorial was written by: rosie
This video Tutorial was made by: Jamie E
This is a straight forward tutorial for creating a notification from Airwave for when a particular MAC Address connects to the network. This can be used to track lost/stolen assets, AUP violators, or for VIP alerts to make sure you keep busy when they arrive at your building.
1. Log into Airwave and head to the System tab and select Triggers
2. Click Add
3. Select “Connected Clients” as the trigger type
4. Enter the MAC addresses of the devices you want to receive notifications for
5. Add a helpful Note such as this one
6. Select email as the “Additional Notification Options”
7. Enter a “Sender Address”
8. Enter “Recipient Email Addresses”
9. Click Add
In conclusion this tutorial is used to notify a recipient via email when one or a group of particular MAC Addresses connect to the network.
If you found my post helpful, please give kudos!
-Rosie
Version history
Revision #:
4 of 4
Last update:
‎04-17-2014 06:38 AM
Updated by:
Labels (1)
Contributors
