Aruba Controller Password Reset - Jan 2014
MVP
MVP
Tutorial by Hendrik
If you have forgotten or lost your Aruba Controllers Password it can be reset following the bellow steps.
  1. Connect to the cotroller via Console cable
  2. Login using "password" as the user name and use "forgetme!" as the password.
  3. Type "enable" to enter the enable mode
  4. Type "conf term" to enter configuration mode
  5. In configuration mode, enter ‘mgmt-user admin root’ and reset the password
  6. Re-login using the new admin password you just set.
  7. Enter "enable" and then "conf term" to enter configuration mode
  8. Type ‘enable secret’ reset the enable mode password.
  9. Lastly perform a "write mem" to save your new passwords and make it persistent
Example:
User: password
Password: forgetme!
(aruba) >enable
Password: enable
(aruba) #configure terminal
Enter Configuration commands, one per line. End with CNTL/Z
(aruba) (config) #mgmt-user admin root
Password:
Re-Type password:
(aruba) (config) #exit
(aruba) #exit
(aruba) >exit
User: admin
Password:
(aruba) >enable
Password: enable
(aruba) (config) #enable secret
Password:
Re-Type password:
(aruba) (config) #write memory
Please give Kudos if you learnt something new or useful Smiley Happy
Version history
Revision #:
2 of 2
Last update:
‎02-25-2014 03:25 PM
Updated by:
Labels (2)
Contributors
Comments
sshimon
When I enter write memory at the end, it says "You don't have permission to execute the coomand."
Why do I only have this message?
Regards
Simon
