Auto-Size (for smart devices/mobiles) Captive portal - 1 click login - Mar 2014
Community Manager
Community Manager
The tutorial was by: kdisc98
I edited/converted some script for my own usage - and i decided to share it with you. **ATTACHED AS ZIP FILE**
 (based on HTML/CSS/Java)
The script is enable u to build a auto-size captive portal page with 1 click login.
(Good for guest enviroments)
Tested on: Windows mobile/BB/Apple devices/Android devices/Windows Laptops/Linux Laptops
Screenshots:
Before uploading it to your controller - edit the index.html as u want( change the ip to your controller ip)
edit the user agreement for your needs (change XXX  & Carlton Telaviv to your desire site/confrence name)
Be sure to enable guest login under your l3 aaa profile - captive portal profile
That's it - upload all the content + the index.html - and use it whenever u need it - your clients will be happy with minimalstic fast login page that auto-size/fit itself to any device.
Enjoy Smiley Happy
Version history
Revision #:
1 of 1
Last update:
‎04-14-2014 12:27 PM
Updated by:
Labels (1)
Comments
Thanks for the info! Definitely going to give this a try.
