Found Address IP of IAP - Mar 2014
Community Manager
Community Manager
The tutorial was by: alagoutte
Sometimes, it is not easy to find the IP address of IAP... (no closed IAP or  documentation about IP configuration...)
There is a easy method for finding the IP Address of IAP.
You need a lasted build of Wireshark (> 1.11.3 available here, will be available in next major release 1.12 in may/june 2014).
Set a laptop in some network (vlan) like IAP and launch capture :
set aruba_iap display filter in Wireshark
And i will display the list of IAP will be broadcast in the network with the IP of IAP :
Now, launch your favorite browser and launch a connection to the IP found by Wireshark ! :-)
Version history
Revision #:
1 of 1
Last update:
‎04-14-2014 01:21 PM
Updated by:
Labels (1)
Contributors
