Using ClearPass To Manage Controller Login - Feb 2014
MVP
MVP
Tutorial By:
Video Tutorial by: Jamie E
In this tutorial I’ll show you how to create a ClearPass service for login to the Aruba controller.  A member of Active Directory group Engineer will be assigned Aruba mgmt. “root” role, while a member of AD group Guest-Provisioning will be assigned Aruba mgmt. “guest-provisioning” role.
To make it easy to follow the process of building this ClearPass service, I also include a flow chart.
If you found my post helpful, please give kudos!
Version history
Revision #:
1 of 1
Last update:
‎04-22-2014 09:49 PM
Updated by:
Contributors
