AMP 7.0.7: VisualRF engine disabled; won't come up
If you are on version 7.0.7 and you are seeing a message saying that the VisualRF engine is disabled when you try to load the Floor Plans page, you may have encountered a known defect. As a side effect you may also be seeing a "Nightly Maintenance failed" message on the Home > Overview page. If both of these is true, please see the related Knowledge Base article:
Version history
Revision #:
2 of 2
Last update:
‎06-17-2014 11:03 AM
Updated by:
Contributors
