AWSP DWG file conversion
AWSP cant import a drawing generated with CAD 2004 or CAD 2005. This is an MS Visio problem and we are working with Microsoft to resolve it.
The workaround is to utilize a free CAD to JPG converter tool such as DWG Viewer:
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 10:31 AM
Updated by:
Labels (1)
