AirWave doesn't show full number of Aruba APs
Problem :
AirWave shows a less number of connected Aruba APs than the controller is reporting. The LAN MAC address of the missing AP(s) ends in ":FE" or ":FF".
Solution :
This is an AOS defect that causes the SNMP response for wlanAPIpAddress OID to not contain any device with LAN MAC that ends in "FE" and "FF". The details are recorded in defect number 54939. AOS release 6.1.3.0 and later contains the fix.
Version history
Revision #:
1 of 1
Last update:
‎06-29-2014 07:55 PM
Updated by:
Labels (1)
Contributors
