Airwave Configuration Management
If using Airwave (AMP < 6.3), and allowing it to do configuration changes, please be aware of a major caveat. After making a configuration change on AMP, the AMP server will write a new startup-configuration file on the controller and REBOOT the controller when done. The reboot and write are part of the same process. With release of AMP 6.3, this will not be the case.
Version history
Revision #:
1 of 1
Last update:
‎07-06-2014 08:21 AM
Updated by:
Labels (1)
