Requirement:Junos Space Network Director
Aruba Airwave network director
Solution:Juniper Networks Junos Space Network Director integrates with Airwave management application and Aruba wireless LAN devices, including Aruba access points and controllers, and to converge Juniper Networks wired technologies such as switching and Aruba wireless LAN technologies for simplified network management.
The integration of these two platforms enables you to:
•View Aruba Device Inventory List in Network Director—The Juniper Networks server automatically retrieves the latest Aruba wireless device inventory from the Aruba server based on the resynchronization interval specified under Preferences. Alternately, you can manually retrieve the device inventory list by clicking the Resynchronize Now option.
•Launch Aruba Airwave from within Network Director—You can launch the context-sensitive pages of Airwave application from within Network Director to manage Aruba wireless devices. For example, you can launch the APs/Devices > List and Reports > Generated pages of Airwave application from the Monitor mode and Report mode of Network Director respectively.
Configuration:Config that needs to be done on Juno network director,
To enable launching the Airwave application from within Network Director:
1.Type the URL required for launching the Airwave application.
2.Type the credentials that are used to log in to the Airwave application.
3.Specify the time in hours after which the Juniper Networks Network Director server synchronizes with the Aruba server to get the latest wireless devices inventory from the Aruba server.
The default synchronize interval is 24 hours. You can enter upto 720 hours as synchronize interval.
Note: If you specify the synchronize interval as 0 hours, the synchronization between the Juniper Networks server and Aruba server does not occur and you will need to manually synchronize these servers to retrieve the latest device inventory. To manually synchronize the servers click the Resynchronize Now button in the Aruba Wireless Device Inventory page.
4.Click Check Connectivity to check the network connection between the Aruba Aiwave application server and Network Director.
5.Click OK.
Configuration in Airwave,
Navigate to Ampsetup -> Juniper -> And We need update Network director name.
VerificationView Aruba Device Inventory List in Network Director—The Juniper Networks server automatically retrieves the latest Aruba wireless device inventory from the Aruba server based on the resynchronization interval specified under Preferences. Alternately, you can manually retrieve the device inventory list by clicking the Resynchronize Now option.
