Airwave - Reclaim default report definitions
Introduction : When you first install AMP, it comes with 20 pre-defined 'canned' reports.  Over time, someone can accidentally delete a definition or two. This article provides the steps to reclaim the lost report definitions.
Answer :
From the Airwave CLI(SSH access):
# cat /var/airwave/license/license.txt
(copy output to a notepad file)
# rm /var/airwave/license/license.txt
From the Airwave webUI:
-Login to AMP
-paste back in the license key
-save
-accept to the Licensing Agreement
On the Reports Definition page, you should see the 20 Daily reports in addition to any pre-existing reports.
If you end up with duplicate definitions from this event, remove the duplicate definitions that do not have a 'Latest Report' link to prevent double reporting.
Version history
Revision #:
1 of 1
Last update:
‎07-08-2014 04:26 PM
Updated by:
Labels (1)
Contributors
