Airwave install on VMWare Workstation fails
Symptoms
AirWave installation on a Vm Workstation failed
Diagnosis
I see the below error while trying to install Airwave on VM Workstation.
Solution
This can be resolved by enabling the Intel VT-x on the instance.
We can get more information about this by browsing to the below URL's
1: http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1003944
2: https://communities.vmware.com/docs/DOC-8970
3: https://communities.vmware.com/docs/DOC-8978
4: http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1003944
5: http://www.virtualizationadmin.com/blogs/lowe/news/enable-virtual-vt-xamd-v-support-in-vmware-workstation-8-183.html
Version history
Revision #:
2 of 2
Last update:
‎06-01-2014 08:06 PM
Updated by:
Labels (1)
Contributors
