Apply All option in Airwave
MVP
MVP
Q:
What is the use of 'Apply All' option in Modify Devices option of Airwave?
A:
Apply All option is introduced in Airwave 8.2.
If you see above screenshots, the number of devices is 1953 and maximum of 500 devices could be seen/selected in a page and other devices could be viewed/selected by navigating to consecutive pages. In order to minimize these navigation 'Apply All' option was introduced.
When option 'Monitor Only + Firmware Upgrades + Apply All' is used, all the devices under group/folders will be changed to monitor mode irrespective of selected/non-selected. It is a good option, however, in case of changes make sure to review what devices are present in the list and if this option is applicable to the situation.
Version history
Revision #:
2 of 2
Last update:
‎06-12-2018 01:29 PM
Updated by:
Labels (1)
Contributors
