Cannot find AP catalog
Question   Cannot find AP catalog?
Issue : Error message pops up when planning AP's in VisualRf after drawing a region saying "Cannot retrieve AP catalog"
Solution :
1. Make sure you are using IE7 or greater (or any other supported browser like Firefox) for Visual Rf to work.
2. Try a different browser and see if you have the same issue.
3. We've seen this issue basically on IE6 due to its security settings. So, make sure you have IE7 or more and try on another browser.
Version history
Revision #:
1 of 1
Last update:
‎06-26-2014 03:27 PM
Labels (1)
Contributors
