Checking SELinux status and disable
When you get error while pushing ios config to IOS AP in manage mode look for SELINUX is disable or not.
SELINUX can also cause other issues with the proper operation and function of AirWave. SELINUX should *always* be disabled.
Command to check:
# sestatus ( It should be disable " SELinux status: disabled )
If it is enable please disable it by editing /etc/selinux/config file.
You can use "VI" editor
#vi /etc/selinux/config
edit the SELINUX line to
SELINUX=disabled
or
If you are not comfortable with "vi" editor you can use following command to disable SELINUX.
# make disable_selinux
Please reboot the system after making this change.
# reboot
Version history
Revision #:
1 of 1
Last update:
‎06-10-2014 08:30 PM
Updated by:
Labels (1)
Contributors
