Monitoring, Management & Location Tracking
Cisco 3750 running 12.2.25 SEE1 3750 IOS. crashing in AMP due to Cisco memory leak
Issue: Cisco 3750 switches crashing during SNMP polling in AMP.
CSCsg18188 Bug Details
Top of Form
Memory leak when polling cswSwitchInfoTable via SNMP
Symptom: Memory leak leading to switch crash
Conditions: This has been observed on stacks of Cisco3750 running Cisco IOS software 12.2(25)SEE1 when polling the SNMP object cswSwitchInfoTable from the CISCO-STACKWISE-MIB
Workaround: Do not poll cswSwitchInfoTable, or create a view to block the access to it.
Bottom of Form
My recommendation would be that you consider a migration of code on the switch stacks that experienced the problem to a version that contains the fix for the above defect.
The other image you are running in production, 122-46SE, is not affected by CSCsg18189.
Please feel free to contact for more information.
Version history
Revision #:
1 of 1
Last update:
‎06-17-2014 10:58 AM
Updated by:
Labels (1)
