Problem:
With Clarity Synthetic available with 8.2.3 version of Airwave one can perform synthetic tests to determine issues with client connection with Aruba APs. These tests can be performed from the Home-->Clarity-->Synthetic tests page as shown below.
Please refer to the Airwave Clarity Beta guide for more information on how to perform these tests.
Diagnostics:One such test result can show up with the following error message:
Below is a snippet from the Clarity log within Airwave located at /var/log.
2016-12-25 03:06:15.324 WARN SyntheticTestServiceStartup - Starting ClaritySynthetic App...
2016-12-25 03:06:15.596 WARN SyntheticTestServiceStartup - Flushing clarity keys
2016-12-25 03:06:21.747 WARN SyntheticTestServiceStartup - Clarity keys deleted from redis
2016-12-25 03:06:21.758 WARN SyntheticTestServiceStartup - clarityDatabase dbfileName: clarity_database.xml
2016-12-25 03:06:25.217 WARN SyntheticTestServiceStartup - Starting Core Services...
2016-12-25 03:06:25.378 INFO SyntheticTestServiceStartup - waiting for the DatabaseService to bootstrap
2016-12-25 03:06:35.382 INFO SyntheticTestServiceStartup - Starting ClaritySyntheticService (Websocket)...
2016-12-25 03:07:20.064 INFO SyntheticTestServiceStartup - Starting ClaritySyntheticWebServer...
2016-12-25 03:07:20.088 INFO SyntheticTestServiceStartup - Starting HeartbeatMonitoringService...
2016-12-25 03:07:20.093 WARN SyntheticTestManagerImpl - Reset all APs
2016-12-25 03:07:20.396 INFO ClaritySyntheticServiceImpl - Akka actor started [pool_size:3]
2016-12-25 03:07:20.396 WARN ClaritySyntheticServiceImpl - Cert path=/usr/local/airwave/lib/java/airwave.jks secure port is 60001
2016-12-25 03:07:22.009 INFO log - Logging initialized @68968ms
2016-12-25 03:07:22.932 WARN ClarityWebServer - secure port -1
2016-12-25 03:07:22.937 INFO Server - jetty-9.3.7.v20160115
2016-12-25 03:07:23.026 WARN ClarityWebSocket - secure port 60001
2016-12-25 03:07:23.029 INFO Server - jetty-9.3.7.v20160115
2016-12-25 03:07:26.097 INFO ContextHandler - Started o.e.j.s.ServletContextHandler@9378676{/clarity,null,AVAILABLE}
2016-12-25 03:07:26.312 INFO ServerConnector - Started ServerConnector@7ad58409{HTTP/1.1,[http/1.1]}{0.0.0.0:8081}
2016-12-25 03:07:26.475 INFO Server - Started @73452ms
2016-12-25 03:07:26.475 INFO ClaritySyntheticWebServiceImpl - Jetty WebServer started [port=8081]
2016-12-25 03:07:26.774 INFO ContextHandler - Started o.e.j.s.ServletContextHandler@5c5c14cd{/,null,AVAILABLE}
2016-12-25 03:07:26.775 INFO ServerConnector - Started ServerConnector@515f7902{HTTP/1.1,[http/1.1]}{0.0.0.0:60000}
2016-12-25 03:07:26.993 INFO SslContextFactory - x509=X509@3bd8643a(1,h=[10.1.2.13],w=[]) for SslContextFactory@57b93fed(file:///usr/local/airwave/lib/java/airwave.jks,null)
2016-12-25 03:07:27.644 INFO ServerConnector - Started ServerConnector@7bb233c9{SSL,[ssl, http/1.1]}{0.0.0.0:60001}
2016-12-25 03:07:27.669 INFO Server - Started @74646ms
2016-12-25 03:07:27.669 INFO ClaritySyntheticServiceImpl - Jetty WebSocket started [port:60000]
Fetching all Test Servers from backend
2016-12-25 03:09:30.694 INFO FetchAllTestServerControl - All the test server ids are: []
jsonArray: [{"BSSID":"84:D4:7E:D6:B1:B0","SUMMARYDATA":[{"result":"Failed:Test WPA aborted for target BSSID 84:D4:7E:D6:B1:B0"}],"TESTID":"74ad1040-85fa-fb73-0e28-67d97dad580e","INITDATA":{"webSocketStatus":"FAILURE","apForwardModeChanged":"FALSE","apForwardingMode":"None","mgmtEntityConfigChanged":"FALSE","result":"Failed: Failed to establish gre & websocket connection with syntheticAP","startTime":"2017-01-12 15:24:26.844307 UTC","greStatus":"FAILURE"},"WPADATA":{"startTime":"2017-01-12 15:24:58.083167 UTC","wpaassociation":{"bssid":"84:d4:7e:d6:b1:b0","result":"Success","startTime":"2017-01-12 15:24:58.818505 UTC","time":120,"retryCount":1,"groupText":"Association"},"wpascan":{"result":"Success","startTime":"2017-01-12 15:24:58.085822 UTC","time":715,"retryCount":1,"BSSIDS":[{"scanResultCount":1,"BSSID":"84:d4:7e:d6:b1:b0"}],"groupText":"Scan"},"result":"Failed:Deauth received","wpa4wayhandshake":{"WPAKey4TxRetryCount":0,"WPAKey2TxRetryCount":0,"WPAKey3RXRetryCount":0,"groupText":"4 Way Handshake","startTime":"1970-01-01 00:00:00.000000 UTC","time":0,"retryCount":0,"WPAKey1RxRetryCount":0,"result":"Failed"},"clientMACAddress":"84:d4:7e:d6:b1:bf"}}]
2017-01-12 02:30:11.056 WARN TestDataHandler - no failed RESULT
2017-01-12 02:30:11.056 WARN TestDataHandler - no failed Result
2017-01-12 02:30:11.056 WARN TestDataHandler - result contains failed - setting status to errorFailed: Failed to establish gre & websocket connection with syntheticAP
2017-01-12 02:30:11.056 INFO TestDataHandler - bldrString is
"ERRORDATA":
From the Clarity log we see that there is a failure with regards to the test information requested by Clarity for the specified parameters(SSID & Client).
SolutionThe error message is due to NAT enabled in contorller for internet access in this case. Once NAT was disabled the test was successful as show in the image below.
The AP system profile used must not have NAT enabled for the Clarity synthetic test to be succesful. If NATed the information will be routed elsewhere and not reach the Clarity engine.
