Monitoring, Management & Location Tracking
Clients not locating correctly in AirWave and Client stats not updated on Cisco Controllers running 5.1.151
Summary of the Issue : Clients not locating correctly in Airwave. Client stats and Bandwidth data is not getting updated properly
This is due to a bug with Cisco controller firmware 5.1.151:
Cisco BUG ID: CSCso16454 - CAPWAP: client stats are not updated, all counters zero always
Troubleshooting command:
Run the following command from the controller CLI:
(Cisco Controller) >show client detail <Client_MAC_ADDRESS>
Client Statistics:
Number of Bytes Received................... 0
Number of Bytes Sent....................... 0
--More-- or (q)uit
Number of Packets Received................. 0
Number of Packets Sent..................... 0
Number of EAP Id Request Msg Timeouts...... 0
Number of EAP Request Msg Timeouts......... 0
Number of EAP Key Msg Timeouts............. 0
Number of Policy Errors.................... 0
Radio Signal Strength Indicator............ Unavailable
Signal to Noise Ratio...................... Unavailable
Nearby AP Statistics:
TxExcessiveRetries: 0
TxRetries: 0
RtsSuccessCnt: 0
RtsFailCnt: 0
TxFiltered: 0
TxRateProfile: [0,0,0,0,0,0,0,0,0,0,0,0]
Resolution: The bugs is resolved in the latest version of the 5.2 code and higher. Upgrading the controller to 5.2 firmware should fix this issue.
Version history
Revision #:
1 of 1
Last update:
‎06-10-2014 08:37 PM
Updated by:
Contributors
