Configuring FreeRADIUS to authenticate AWMS Users
This document describes configuring AWMS and FreeRADIUS so that AWMS users are authenticated against a FreeRADIUS server. The process involes making 3 configuration changes on FreeRADIUS, and defining that FreeRADIUS server as an auth server for the AWMS.
CONFIGURING FREERADIUS:
I. For each user, add an Aruba-Admin-Role attribute:
Syntax:
<username> User-Password := "<password>"
Aruba-Admin-Role = "<name of awms role>
Examples:
jane User-Password := "password123"
Aruba-Admin-Role = "AMP Administration"
john User-Password := "topsecret"
Aruba-Admin-Role = "ResNet AP Monitoring"
Framed-IP-Address = 192.168.1.1
Framed-IP-Netmask = 255.255.255.0
II. Define a shared secret (which also must be added on the AWMS):
In /etc/raddb/clients.conf add a section allowing the AWMS (or a network) to be a RADIUS client:
Syntax:
client <ip address or network> {
secret = <secret>
shortname = <label>
Example:
client 10.2.32.0/24 {
secret = airwave
shortname = corp_dev_net
III. Copy dictionary.aruba from the AWMS's filesystem to the FreeRADIUS server:
Location on AWMS: /opt/airwave/share/freeradius/dictionary.aruba
Copy to this directory on FreeRADIUS: /usr/share/freeradius/dictionary.aruba
CONFIGURING AWMS:
On the AMP Setup -> Authentication page, enable RADIUS Auth, and provide the ip addresses, ports and secrets for your FreeRADIUS servers.
Version history
Revision #:
1 of 1
Last update:
‎06-06-2014 03:38 PM
Updated by:
Contributors
Comments
Komorebi
There is one extra step that is needed to be done in AirWave.
The role "AMP Administration" needs to be created in Airwave.
AMP Setup > Roles
Add role.
Set the type to be "AMP Administrator"
Give it a name and click Add, to create a role with the default settings.
I hope this helps.
