There are 2 levels of security that need to be changed to allow ODBC connections to AMP's database. The following instructions refer to config files in /var/lib/pgsql/data/ :1. In hba.conf, add a line for your clients that can connect. In my environment, I added this:host all all 10.51.0.0 255.255.0.0 trustA more secure option is to force username/password login like this:host all all 10.51.0.0 255.255.0.0 ident airwave2. In postgresql.conf this linevirtual_host = 'localhost'defines the addresses that postgres will listen from. Since you want to listen for more addresses than just localhost, you'll need to add entries or just comment out the line. I commented it out like this:#virtual_host = 'localhost'Once I had those two files configured, I restarted postgres like this:# service postgresql restartAnd was able to connect to AMP's database from my laptop via PGAdmin III and with MS Access using ODBC. I understand from my old notes that the ODBC drivers are available inVisualStudio.NET.The default username and password for AMP's database are airwave/airwave.
