Monitoring, Management & Location Tracking
Creating SSL Certificates for AMP in versions 7.1 and earlier
This document describes creating a self-signed SSL certificate to use with AirWave versions 7.1 and earlier.
The easiest solution is to create another self-signed certificate for the server. Here are the steps for creating a self-signed certificate for
# sed s/"localhost.localdomain"/""/ /root/svn/mercury/lib/conf/openssl.cnf > /tmp/openssl.cnf
# /usr/bin/openssl req -new -key /etc/httpd/conf/ssl.key/server.key -x509 -days 1827 -out /etc/httpd/conf/ssl.crt/server.crt -config /tmp/openssl.cnf 2> /dev/null
# service httpd restart > /dev/null
A better solution is to get a certificate from a real Certificate Authority. That would get rid of those annoying "this certificate was issued by a company you have not chosen to trust" errors, and it would make the server a little bit more secure. The process for doing that is described in an article called "How to install your own cert on AMP", which is here:
Version history
Revision #:
1 of 1
Last update:
‎06-10-2014 08:04 PM
Updated by:
Labels (1)
