If you're writing a database (SQL) query to match a pattern anywhere within a string, use the LIKE operator and put percent signs (%) before and after the pattern you want to match. (You can also use a tilde operator (~) and leave out the percent signs.)EXAMPLE:
Set to ignored all rogues where SSID contains the string 'x00':> UPDATE rogue_ap SET ignored = 1 WHERE ssid LIKE '%x00%'; --OR--> UPDATE rogue_ap SET ignored = 1 WHERE ssid ~ 'x00'; Here are some other operator combinations you might find useful:~~ . . . . . . . . . . .same as: LIKE% (percent): . . . matches any string of zero or more characters_ (underscore): . matches any single characterILIKE . . . . . . . . .same as LIKE, but case insensitiveNOT . . . . . . . . . .inverse; matches everything that is NOT matched by LIKE* . . . . . . . . . . . .case insensitive (same as ILIKE); used with ~ or ~~ ! (bang) . . . . . . inverse (same as NOT); used with ~ or ~~If the pattern does not contain percent signs or an underscore, then the pattern only represents the string itself; in that case LIKE acts like the equals (=) operator. To match a pattern anywhere within a string, the pattern must therefore start and end with a percent sign (%).EXAMPLE:
On all controllers where value is null, change it to empty string:
NOTE: those are two single quotes ( ' ) after the = > UPDATE device_config SET value = '' WHERE name LIKE '%controller%' AND value IS NULL;See also http://www.postgresql.org/docs/7.3/static/functions-matching.html
