Disassociation Traps from Cisco IOS
Below is a list of IEEE 802.11 Disassociation codes for the OID dot11DeauthenticateReason. AirWave supports logging RADIUS Events from Cisco IOS APs for all the codes from 13-23.
http://blog.michaelfmcnamara.com/2007/11/80211-dissassociation-codes
0 REASON_CODE_80211_SUCCESS
1 REASON_CODE_80211_UNSPECIFIED_ERROR
3 DISASSOCIATION_REASON_CODE_STATION_LEAVING_ESS
4 DISASSOCIATION_REASON_CODE_INACTIVITY
5 DISASSOCIATION_REASON_CODE_STATION_LIMIT_EXCEEDED
6 DISASSOCIATION_REASON_CODE_CLASS_2_PKT_FROM_NON_AUTH
7 DISASSOCIATION_REASON_CODE_CLASS_3_PKT_FROM_NON_ASSOC
8 DISASSOCIATION_REASON_CODE_STATION_LEAVING_BSS
9 DISASSOCIATION_REASON_CODE_STATION_NOT_AUTHENTICATED
13 DISASSOCIATION_REASON_CODE_INVALID_INFORMATION_ELEMENT
14 DISASSOCIATION_REASON_CODE_MIC_FAILURE
15 DISASSOCIATION_REASON_CODE_4WAY_HANDSHAKE_TIMEOUT
16 DISASSOCIATION_REASON_CODE_GROUP_KEY_UPDATE_TIMEOUT
17 DISASSOCIATION_REASON_CODE_4WAY_IE_DIFFERENCE
18 DISASSOCIATION_REASON_CODE_MULTICAST_CIPHER_INVALID
19 DISASSOCIATION_REASON_CODE_UNICAST_CIPHER_INVALID
20 DISASSOCIATION_REASON_CODE_AKMP_NOT_VALID
21 DISASSOCIATION_REASON_CODE_UNSUPPORTED_RSNE_VERSION
22 DISASSOCIATION_REASON_CODE_INVALID_RSNE_CAPABILITIES
23 DISASSOCIATION_REASON_CODE_8021X_AUTHENTICATION_FAILED
44 DISASSOCIATION_REASON_CODE_PSP_TX_PKT_BUFFER_EXCEEDED
77 DISASSOCIATION_REASON_CODE_TRANSMIT_RETRIES_EXCEEDED
Version history
Revision #:
1 of 1
Last update:
‎06-25-2014 02:00 PM
Updated by:
Labels (1)
Contributors
