Monitoring, Management & Location Tracking
Does AWMS support SNMP v3 informs sent from Aruba controllers?
Environment: This article holds good for Airwave versions 7.1 and greater
They are supported in AirWave versions 7.1 and newer.  New SNMP v3 users can be configured on the Device Setup->Communication page.
For all controllers AMP users will need to configure all v3 users that are configured on the controller; please note that snmptrapd is restarted when users are changed or added.
Version history
Revision #:
1 of 1
Last update:
‎06-06-2014 03:37 PM
Updated by:
Labels (1)
Contributors
Comments
WiFi_Client
