Monitoring, Management & Location Tracking
Does Airwave collect VisualRF backup as a part of nightly maintenance
MVP
MVP
Q:
Does Airwave collects VisualRF backup as a part if nightly backup?
A:
The nightly backup file generated as a part of nightly maintenance contains the VRF backup as well.
Starting 8.2.0, Airwave collects a standalone VRF backup file. We can download it from CLI.
We can use SCP to download the file from - /var/airwave-backup/visualrf.
NOTE: Airwave only stores one copy of the file which is generated daily.
Version history
Revision #:
2 of 2
Last update:
‎03-18-2017 11:36 AM
Updated by:
Labels (1)
Contributors
