Monitoring, Management & Location Tracking
Error: There is a problem with your upstream device table
Issue: Error: There is a problem with your upstream device table
I'm seeing the following error:
There is a problem with your upstream device table. Contact AirWave Technical Support...
What does it mean and how can I fix it?
WHAT'S HAPPENING
This happens when CDP repeatedly flip flops about the upstream/downstream relationship of two devices. Each time we see the relationship change, we update the upstream_device table. If this happens repeatedly, the left_ and right_visit numbers can grow very large causing the error.
SOLUTION
It would be helpful to us if you could send us the output from the following command:
# dbc "select a.id, a.type, a.name, u.left_visit, u.right_visit from ap a, upstream_device u where a.id = u.ap_id order by u.right_visit desc limit 15"
To clean up the upstream_device table you can run the following commands:
# disable_amp
# /usr/local/airwave/bin/compact_upstream_device_table
# enable_amp
If the error message appears again, you can repeat these steps.
We expect to have the error fixed in an upcoming release.
Version history
Revision #:
2 of 2
Last update:
‎06-26-2014 04:31 PM
Labels (2)
Contributors
