Error loading page: lan_hostname does not exist
An error occurs when trying to load a page that contains client data (ex: APs/Devices > Monitor ; Users > Connected). The error looks something like this:
[Mon Mar 29 18:48:59 2010] [error] [client 192.168.223.21] get_objects() - DBD::Pg::st execute failed: ERROR: column t1.lan_hostname does not exist
WHAT'S GOING ON:
Prior to upgrade
- On the Client table in the UI the user has selected the "LAN Hostname" column to sort on
- This is entered into the list_pref table in the db
The AMP is upgraded to 7.0
- bug in building page is introduced
- customer tries to load page
- page crashes
HOW TO FIX IT:
Verify that this is the correct issue:
# dbc "select * from list_pref where sort_field = 'lan_hostname';"
Does the query return entries where sort_field = 'lan_hostname'?
If so, delete those entries:
# dbc "delete from list_pref where sort_field = 'lan_hostname';"
Reload page to check that all is well.
Customer should upgrade to 7.0.2 when available.
Version history
Revision #:
1 of 1
Last update:
‎06-17-2014 09:28 AM
Updated by:
Contributors
