Error pushing guest users
When AMP pushes out a guest user to controllers, it will record an error message in that user's status column any time that it fails on one controller. If the user is successfully added to 99 controllers and it fails on 1, then an error will show.
We're looking into ways to improve this.
For now (versions 7.0 and earlier) an easy workaround is to not display the Status column to the users who are creating guest users.
Version history
Revision #:
1 of 1
Last update:
‎06-16-2014 10:13 AM
Updated by:
Contributors
