I just upgraded to 6.1 and I'm getting an error when doing a search that looks something like this:[Thu Oct 30 12:34:41 2008] [error] [client 123.5.6.7] Undefinedsubroutine &Mercury:: DB::ClientFirstLast::lan_ip called at/usr/local/airwave/lib/perl/Mercury/Role/Autoloads.pm line 50 Solution:Run the following command on the AMP command line interface:# echo "delete from list_pref where list_namespace = 'client_list' and uri = '/search'" | dbIf this doesn't work, please contact AirWave Support.I just upgraded to 6.1 and I'm getting an error when doing a search that looks something like this:[Thu Oct 30 12:34:41 2008 ] [error] [client 123.5.6.7] Undefinedsubroutine &Mercury:: DB::ClientFirstLast::lan_ip called at/usr/local/airwave/lib/perl/Mercury/Role/Autoloads.pm line 50 Solution:Run the following command on the AMP command line interface:# echo "delete from list_pref where list_namespace = 'client_list' and uri = '/search'" | dbIf this doesn't work, please contact AirWave Support.I just upgraded to 6.1 and I'm getting an error when doing a search that looks something like this:[Thu Oct 30 12:34:41 2008 ] [error] [client 123.5.6.7] Undefinedsubroutine &Mercury:: DB::ClientFirstLast::lan_ip called at/usr/local/airwave/lib/perl/Mercury/Role/Autoloads.pm line 50 Solution:Run the following command on the AMP command line interface:# echo "delete from list_pref where list_namespace = 'client_list' and uri = '/search'" | dbIf this doesn't work, please contact AirWave Support.
