Typically support recommends starting SCREEN session for upgrades, restores, and manual backups. In some cases, you may run into the following error:screen: error while loading shared libraries: libutempter.so.0: cannot open shared object file: No such file or directoryTo resolve this, you'll want to do the following:If your AMP has access to the internet:# yum install utempterIf your AMP doesn't have access to the internet, then you'll need to download the libutempter rpm package:libutempter-1.1.4-4.el5.i386libutempter-1.1.4-4.el5.x86_64
