Example of accessing AMP APIs using Zend
This example uses the Zend Framework (framework.zend.com) to get data from ap_list.xml:
$baseUrl = "https://myampserver.domain.com";
$username = "myuser";
$password = "mypassword";
$client = new Zend_Http_Client();
$client->setCookieJar();
$client->setUri($baseUrl."/LOGIN");
$client->setParameterPost('credential_0',$username);
$client->setParameterPost('credential_1',$password);
// we are simply authenticating
$client->setParameterPost('destination',$baseUrl);
$response = $client->request('POST');
// Then we can go on and use other uri's for example getting an AP with
id of '123' in xml
// Just comment out the $arguments line if you want to grab all of them
$arguments = array('id' => 123);
$client->setUri($baseUrl."/ap_list.xml");
if(isset($arguments))
foreach($arguments as $arg => $value)
$client->setParameterGet($arg, $value);
$response = $client->request('GET');
$xml = new SimpleXMLElement($response->getBody());
Version history
Revision #:
1 of 1
Last update:
‎06-27-2014 12:07 PM
Updated by:
Labels (1)
Contributors
