Monitoring, Management & Location Tracking
Field Notice :: DE10953 :: AirWave 7.4 invalid configuration push to Cisco WLC Cisco WLC 7.0
An issue was identified in AirWave 7.4.0-7.4.3 that can cause AirWave to push an invalid configuration to Cisco Wireless LAN Controllers running WLC 7.0.98, which could cause a network outage. The issue has been resolved in 7.4.4. Other versions of WLC 7.0 prior to 7.0.116.0 may be affected.
Workaround: Keep Devices in Monitor Only mode in AirWave
Fix: Upgrade to AirWave 7.4.4 Release
Release Notes: http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=6958
Version history
Revision #:
1 of 1
Last update:
‎06-25-2014 03:43 PM
Updated by:
Labels (1)
Contributors
