Monitoring, Management & Location Tracking
For AWMS 6.3: Important kernel security and bug fix updates (RedHat Security Advisories - RHSA)
Important: Kernel security and bug fix update.
Security Advisories RHSA-2008:0508-21 and RHSA-2008:0519-24 were issued by Red Hat on 2008-06-25;
RHSA-2009:0326-1 was issued on 2009-04-01;
RHSA-2009:0473-1 was issued on 2009-05-07.
The packages in the CentOS operating system bundled with the AWMS server are developed by a third party; AirWave support recommends updating the kernel version according to the security advisory from Red Hat Network. This is particularly important if you have made any custom modifications to the operating system or are running Red Hat Linux rather than CentOS. Please refer to the linked security advisory for more information about the specific issues addressed in the new version of the kernel.
Post-update issues:
eth0 not found after reboot
We have seen this happen on a few occasions and have found three possible solutions.
1. Swap to eth1, then swap back to eth0.
2. If that doesn't work, reboot again. (This has worked for us in a few instances. On one occasion a user had to reboot four times to get it to work.)
3. As an alternate to #2 above: unplug eth0, reboot, plug eth0 back in again.
Version history
Revision #:
1 of 1
Last update:
‎06-24-2014 12:30 PM
Updated by:
Labels (1)
