Get details of newly added AP in VisualRF
Normally VisualRF's database takes time to fetch the details of a newly added device from AMP's database, based on the value configured for Synchronization Timer under VisualRF's Setup page.
Usually VisualRF is restarted to expedite this process.
From AirWave 8.0 version, we can make VisualRF poll the AMP's database to fetch the information on demand without restarting VisualRF.
AP is in AirWave but not visible in VisualRF:
To make VisualRF fetch the details of the newly added device or updated details of an existing device in AirWave, please navigate to https://<amp_server_ip>/visualrf/poll_aps_now.xml. Once VisualRF is able to fetch the details the following message will be displayed:
User-added image
Polled the poll_aps_now.xml by navigating to https://<amp_server_ip>/visualrf/poll_aps_now.xml
Now we are able to locate the AP in VisualRF
Poll the AirWave database using the poll_aps_now.xml
Version history
Revision #:
2 of 2
Last update:
‎06-25-2015 01:12 PM
Updated by:
Labels (1)
