Following are instructions for installing HP/Compaq Insight Manager on the AMP:Step 1: SCP the two files over to the server:hpasm-7.8.0-88.rhel4.i386.rpm <- This is the actual HP agentshpsmh-2.1.9-178.linux.i386.rpm <- This is the HP web portal to the agentsStep 2: Type 'rpm -i hpasm-7.8.0-88.rhel4.i386.rpm'Step 3: Type 'hpasm activate' Take the default values. You will need the SNMP RW and RO strings at this point.Step 4: Type rpm i --nopre hpsmh-2.1.9-178.linux.i386.rpm ' <- - The nopre is required to keep the rpm from erroring out on CentOS vs. RedHat. This rpm MUST be run after the hpasm rpm since the pre-install scripts in the hpsmh rpm arent being run.Step 5: Type 'perl /usr/local/hp/hpSMHSetup.pl'This will configure the web server.Add Group -> Administrator with name '0'IP Binding enable (type 1)Next page enter the Ip address and mask of the serverStep 6: Type /etc/init.d/hpasm reconfigureWhen going through this menu this time, select 'y' to use existing snmpd.conf.Step 7: Type 'vi /etc/snmp/snmpd.conf'Change these two lines:rwcommunity xxxstringxxx 127.0.0.1rocommunity xxxstringxxx 127.0.0.1to read:rwcommunity xxxstringxxxrwcommunity xxxstringxxxStep 8: Type 'service snmpd restart'Step 9: type 'user add xxusernamexx'Step 10: type 'passwd xxusernamexx' and put in a password for the user.Step 11: type 'vi /etc/passwd 'Scroll to the bottom of the list and change the new users UID and GroupID to 0 (4th and 5th column).Step 12: Connect to the server using https://xxx.xxx.xxx.xxx:2381 and the username and password that you created in steps 9 and 10.
