Monitoring, Management & Location Tracking
How To Fix Offending key in ~/.ssh/known_hosts file
MVP
MVP
Problem:
Sometimes we may face issues when we SSH or SCP from one Airwave box to another when the RSA key fingerprint is changed
Diagnostics:
Following error will be displayed when the remote host key changes (after you’ve connected earlier with a valid remote host key).
Solution
We have to remove the offending key to proceed further. Use the following command to remove the offending key,
# sed -i '1d' ~/.ssh/known_hosts
Note: Change the 1d according to the line number shown.
Now we should be able to login successfully.
Version history
Revision #:
2 of 2
Last update:
‎07-25-2016 04:05 PM
Updated by:
Labels (1)
Contributors
Comments
FPU_RB
This doesn't work without CLI access which was taken away in Airwave 8.2.4. If there's another way, please let me know.
