How do I hide device credentials in the GUI?
If the user does not need access to the AP -> Manage page at all, you could simply limit their role to a Monitoring or Audit user to prevent them from having access to the plain-text credentials. The option for hiding the credentials for all users can be enabled via a database command:
1. Log in to the AMP console as root directly or via SSH
2. Type db to access the database
[root@kelvin ~]# db
Welcome to psql 8.1.3, the PostgreSQL interactive terminal.
Type: \copyright for distribution terms
\h for help with SQL commands
\? for help with psql commands
\g or terminate with semicolon to execute query
\q to quit
airwave=>
3. Update the hide_secrets field
airwave=> update seas_config set hide_secrets=1;
UPDATE 1
airwave=>
4. Type \q to quit the database.
airwave=> \q
[root@kelvin ~]#
Once that field is toggled, the AMP will no longer display the AP credentials in the web interface.
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 10:03 AM
Updated by:
Labels (2)
Contributors
