From the AMP command line interface you can generate custom reports by specifying the correct database query. In 6.2 and newer, use the dbcsv alias:# dbcsv "select id, name from ap"In older versions:To have that report output in comma separated value (CSV) format, you just need to add a few formatting options when you run the query. The basic format of your command will look something like this:echo "[QUERY]" | psql -Uairwave airwave [FORMATTING_OPTIONS] --output [CSV_OUTPUT_FILE]The following example generates a CSV file containing a list of all APs with their associated Group and Folder...FORMATTED FOR EASIER READING (also uses long versions of psql options):echo"select ap.name, ap_group.name, ap_folder.namefrom ap, ap_group, ap_folderwhere ap.ap_folder_id=ap_folder.id and ap.ap_group_id=ap_group.id" |psql -Uairwave airwave --no-align --field-separator , --tuples-only--output [CSV_OUTPUT_FILE][Example CSV_OUTPUT_FILE: /tmp/db_output.csv]FORMATTED FOR EASY COPY AND PASTE (uses abbreviated versions of psql options):echo "select ap.name, ap_group.name, ap_folder.name from ap, ap_group, ap_folder where ap.ap_folder_id=ap_folder.id and ap.ap_group_id=ap_group.id" | psql -Uairwave airwave -A -F , -t -o [CSV_OUTPUT_FILE]
