Monitoring, Management & Location Tracking
How does Airwave copies flashback up from the controller
MVP
MVP
Q:
How does Airwave copies flashback up from the controller?
A:
Airwave SSHs to Aruba controller and run the command to SCP the flashbackup to Airwave's  /tmp/<filename> so we need to make sure scp is allowed between controller and Airwave on the firewall.
Version history
Revision #:
2 of 2
Last update:
‎08-03-2015 05:59 AM
Updated by:
Labels (1)
Contributors
