I have a cluster of 5 IAP - 105's and they are being monitored/managed by Airwave. What should I expect when I add an IAP 135 to the existing cluster.
This article implies to all versions of Airwave
Different IAP hardware requires different firmware version to operate. Below is the details of it.
If we have a cluster with IAP 105's (they run on ArubaInstant_Orion) and we add a new IAP - 135 (it runs ArubaInstant_Cassiopeia), then the VC (Virtual Controller) would not be able to upgrade the IAP - 135 to the code of the cluster.If Airwave is monitoring or managing the cluster and we have the below options enabled, the IAP will fetch the firmware file from Airwave and instantly upgrade to the code of the cluster.We must have the firmware file uploaded on the Airwave.Navigate to Device Setup -> Upload Firmware and files and add the firmware file.If the IAP are in monitor mode, we must allow firmware upgrade in Monitor only Mode.Navigate to AMP Setup -> general page and enable the below option.
