How does Airwave read upstream device info?
Environment : Valid for all versions of Airwave
Upstream device info is read using CDP (Cisco Discovery Protocol) or using the bridge forwarding tables.
If your managed network device is in the list of supported devices by Airwave, we should be able to read the bridge forwarding table to get the upstream device info for non-Cisco devices.
Version history
Revision #:
1 of 1
Last update:
‎04-08-2015 04:22 AM
Updated by:
Labels (1)
