Monitoring, Management & Location Tracking
How should a Locations folder look for outdoorplanner KMZ file?
Environment : Outdoor Planner
  • The “Locations” folder cannot be the top folder
    • There must be a master folder – usually with the name of the project.
    • The Locations folder must be 1 level down from this folder.  Like this:
Locations folder in the KMZ
If the locations folder is not in the order shown above you may see the following error " Variable is undefined"
Version history
Revision #:
1 of 1
Last update:
‎06-29-2014 11:07 AM
Updated by:
Labels (1)
