How to Disable user idle timeout
MVP
MVP
Q:
How to Disable user idle timeout?
A:
This feature allows user to disable timeout that means it will not prompt to login again. This will be a good feature if you want to continuously monitor the activities in Network through Airwave from a Dedicated Screen/Monitor.
In order to use this feature, you need to create a Role with allow disable timeout parameter. Then assign this role to the user.
The users with this role Role will have ability to Disable Timeout.
Steps to configure this:
1. Navigate to AMP Setup > Roles > Create a new Role. While configuring the role make sure to select "Allow user to disable timeout:" option.
Note: Disable Timeout won't prompt you to login again. Hence, its recommended to user the option for Read Only Roles.
2. Now, create a user from AMP Setup > Users > Add user and map the role with Disable timeout option.
3. Once they login they can navigate to Home > User Info > Display Preferences > Check "yes"
Version history
Revision #:
2 of 2
Last update:
‎02-01-2017 12:20 PM
Updated by:
Labels (1)
Contributors
Comments
pkraus@bissinger.de
Hello esupport,
is it possible to configure the idle timeout with aruba iap?
thank you for your answer.
