Monitoring, Management & Location Tracking
How to Enable SNMP Authentication Failure TRAPS in IOS to AMP
Use case -- Show Radius Authentication Failures in AMP.
Commands needed for IOS --
snmp-server enable traps deauthenticate
snmp-server enable traps syslog
snmp-server host <IP_AMP> version 2c public deauthenticate syslog
Note -- SNMP2c is required for these traps and can be used in conjunction with other SNMP versions.
Now the traps can be seen in the AMP GUI in group-->monitor-->"RADIUS Authentication Issues" link (can also be seen from the AMP's CLI /var/log/snmp_trap_handler).
Version history
Revision #:
1 of 1
Last update:
‎06-09-2014 03:22 PM
Updated by:
Labels (1)
