‘Show poe’ can be used to see CLI output for the POE ports on the controller supplying POE for directly-connected AP’s. This is from an 800 controller: (WC0490) #show poe PoE Status ---------- Port Status Voltage(mV) Current(mA) Power (mW) ---- ------ ----------- ----------- ---------- FE1/0 Off N/A N/A N/A FE1/1 Off N/A N/A N/A FE1/2 On 48030 119 5739 FE1/3 On 47870 124 5873 FE1/4 Off N/A N/A N/A FE1/5 Off N/A N/A N/A FE1/6 On 47774 69 3310 FE1/7 On 47550 94 5513 GE 1/8 Off N/A N/A N/A Total Power Usage: 20435 (mW) What the Output Signifies What does the output mean? Use the formula: Power (W) = Volts (V) * Current (A) So… FE1/2 On 48030 119 5739 …means POE voltage measured at output of the controller for this port is 48.030Volts, current sourced is 119mA, for the total of wattage drawn by the AP from this port is 5.739Watt. Output like the following… FE1/6 On 47774 69 3310 …looks like the radio is not on yet, 3.3Watt is quite low. This can occur while the AP is powering up and before the radios have been enabled, ie., before the configuration has been pushed to the AP. ~4.5W or higher is normal. If output like the above is seen for a sustained period of time and if the AP is configured to operate as an AP, then some troubleshooting should be done to determine the source of the low power output. Typical draw for the AP65 is ~6W, and for the AP70 is ~8W (radios active). For the total output for all ports, the 800 has 100Watt power supply, so for 8 ports, each 10W, there should be sufficient power for 8 AP’s.
