Monitoring, Management & Location Tracking
How to avoid SSL errors Printable View | Help for this Page
# cp /etc/httpd/conf/ssl.key/server.key /etc/httpd/conf/ssl.key/server.key.2
Updated commands for getting an SSL certificate (10/21/2008):
# vi /etc/pki/tls/openssl.cnf
Edit the commonName directive on line 67 so it has the DNS name or IP address
(e.g. commonName = example.airwave.com)
# /usr/bin/openssl req -new -nodes -keyout /var/airwave/custom/private.key -out /var/airwave/custom/newcert.csr
# service httpd restart > /dev/null
Old commands for getting an SSL certificate:
# vi /usr/share/ssl/openssl.cnf
# /usr/bin/openssl req -new -key /etc/httpd/conf/ssl.key/server.key -x509 -days 1827 -out /etc/httpd/conf/ssl.crt/server.crt -config /usr/share/ssl/openssl.cnf 2> /dev/null
[See also Knowledge Base article titled "Creating SSL Certificates for AMP"
Version history
Revision #:
1 of 1
Last update:
‎06-06-2014 03:48 PM
Updated by:
Labels (1)
Contributors
